Civil 3D Forum
2011/2012 - Warning: An error occured during save
11 REPLIES 11
Message 1 of 12
Sinc
4902 Views, 11 Replies
Anyone have any info on why I'd get this error when doing an Export to AutoCAD 2010/2007/2004...?  It seems to be innocuous, and irrelevant, but it's disturbing none-the-less.  I haven't been able to identify any reason why it appears, and all drawings seem to work normally, with no problems.  AUDITs turn up no errors.  So I've just been ignoring this message, but it's distracting.  And it doesn't always appear...  although I haven't been able yet to identify what causes it to appear in some drawings, and not others.  I think it only ever happens when there's an XREF, but not sure...  (Maybe when an XREF is in an older version of C3D/LDD/AutoCAD...?)
Sinc
11 REPLIES 11
Message 2 of 12
neilyj666
in reply to: Sinc
Don't know why this error occurs but I get it very regularly in 2012 - seems to occur after QSAVE (when it automatically does a save)
I have had similar messages in the past when XREFS are involved so I bound them first and all seemed ok, then didn't save the original dwg
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 12
antoniovinci
in reply to: Sinc
I can't obviously reply your trouble, but it sounds like a LAN or UAC problem.
Be sure that you have admin privileges on that computer, then unplug Ethernet cable and try again.
Message 4 of 12
Jeff_M
in reply to: Sinc
I've also concluded it is more annoying than a real problem. I see this often after creating a pipe network from a polyline, although I know it's happened after performing other tasks. To be on the safe side I will usually close the drawing and reopen right away.
Message 5 of 12
JeffPaulsen
in reply to: Sinc
We get this this message regularly in 2012. Most people ignore it but I always close the drawing and run a recover. Half the time it finds an error or two other times it finds no errors.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
Message 6 of 12
O.Maille
in reply to: JeffPaulsen
A regular occurance in 2012 for me too. Again rarely appears to relate to anything specific.
Message 7 of 12
rkmcswain
in reply to: Sinc
Yes. Every time I try to export a C3D drawing to another format, like 2004 DXF as an example, since that is what I'm doing at the moment.  (C3D 2013)
R.K. McSwain     | CADpanacea | on twitter
Message 8 of 12
neilyj666
in reply to: rkmcswain
Still happens in 2014....
Message 9 of 12
jdherman
in reply to: neilyj666
We get the same error, but only when a specific dvb project file is loaded.  We can open the drawing and qsave with no message, once we load the dvb, then the message shows up.  We haven't isolated the exact cause, yet.
Message 10 of 12
jdherman
in reply to: jdherman
The error occurs when copying a surface from a xref and pasting in current drawing.  Therefore, it not a generic vba/dvb issue.
Message 11 of 12
loretom
in reply to: Sinc
We get this messages offten.  I Noticed that it happens after adding tag labels to a table.  If I do a recovery, it finds errors and removes the tags.  Once I added them again the error returns.
-Miguel
Message 12 of 12
in reply to: loretom
I get this every time I do a "copy clip" or "copy with base point". Recover says, "no errors" etc. Audit, same... We are running 2015 w/ Trimble running on top of it.
Rail Community
