Hi Kevin,
It appears to be working fine for me. Can you post a drawing? Also what OS
are you working on?
I assume the steps are: click on the circular grip to toggle on subitem
grips and it fatal errors.
Matt Blanchard
Autodesk Civil Test Development
wrote in message news:5570439@discussion.autodesk.com...
I just upgraded to C3D 2008 (very refreshing after putting up with 2007) and
the only problem I've had with it so far is that every time I click on the
circular grip to move the label without a leader, the program has a fatal
error. Has anyone else had this problem? Does anyone know how to fix it?
Kevin Pritchett
C3D 2008
2.4 GHz Core 2 Duo
4GB RAM
XP Pro SP2
