Hey everyone!
I am having this issue, which I have seen before but now more then ever, it is ticking me off....
If I select some items and right click - select similar, then hold shift to deselect some of them, it selects my raster image and I am unable to deselect those specific items.
Is there a way to fix this as it is rather annoying?
Thanks!
Solved by Kyle-Evans. Go to Solution.
Solved by Jeff_M. Go to Solution.
Thank-you thank-you thank-you!
I couldn't use shift-click to deselect objects or to switch my TRIM/EXTEND command, even though I unloaded the image in the x-ref manager. Is that a bug? Who wants to try to select an image while a command is running, or select an image that's unloaded? Anyway, thanks.
Mark Green
Working on Civil 3D in Canada
