Valued Mentor
Sindarin
Message 1 of 4 (525 Views)
1 image (s) found
525 Views, 3 Replies
11-19-2010 08:40 AM
Hey everyone!
I am having this issue, which I have seen before but now more then ever, it is ticking me off....
If I select some items and right click - select similar, then hold shift to deselect some of them, it selects my raster image and I am unable to deselect those specific items.
Is there a way to fix this as it is rather annoying?
Thanks!
Mapioptions.....
I....LOVE...YOU!!!!!!
Thanks!!!!!!
Jeff_M
Message 2 of 4 (523 Views)
Re: 1 image (s) found
11-19-2010 08:43 AM in reply to: Sindarin
Mapioptions.....
Valued Mentor
Sindarin
Message 3 of 4 (520 Views)
11-19-2010 08:45 AM in reply to: Jeff_M
Thanks!!!!!!
troma
Message 4 of 4 (302 Views)
01-31-2012 09:37 AM in reply to: Jeff_M
Thank-you thank-you thank-you!
I couldn't use shift-click to deselect objects or to switch my TRIM/EXTEND command, even though I unloaded the image in the x-ref manager.  Is that a bug?  Who wants to try to select an image while a command is running, or select an image that's unloaded?  Anyway, thanks.
Credit where credit is due! Give kudos or accept as solution whenever you can.
