What do you do with the class of "drafter" that steadfastly refuses to adapt their skill set, the 40-50 year old drafter who doesn't want to do more then they have ever done. I find this person to be very resistant to change and as soon as a deadline is eminent and Civil3D is not showing them a contour line in the manner they are used to see, they blow up the entire TIN and go back to hand drafting contours?
Reviving a ten year old thread like this one is generally considered to be bad form, unless you're adding new information that specifically relates to the original problem.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I started out knowing NOTHING about civil engineering. I remember my instructor trying to explain how to "triangulate a surface" to get contours" but at the time, I was totally lost as to what he was trying to explain. I graduated with an associate's degree in Architectural CADD.
Over time as the designers would give me work to do, I started to understand the engineering involved. After a while, they were able to give me some parameters as you've described and I just ran with it.
A drafter who knows nothing about the design aspect needs to have their hand held for some time (but if you expected to have someone who didn't need that, you should've hired a designer not a drafter), but from personal experience it can be learned "on the job".
Don Ireland
Engineering Design Technician
