Hello there!!!
I have a problem with Autocad Civil 3d 2013: I am trying o run a corridor report witch uses the VBA and i am getting this message:MICROSOFT VISUAL BASIC System error & H80004005 (-2147467259).:Automation error Unspecified Error and after that Microsoft Visual Basic opens and it shows that the report that i am trying to use has some problems.The name of the report is : Report_CorriddorSlopeStake_RO
Can anyone tell me where is the problem?
I have to mention that in Autocad Civil 3D 2012 i didn't have this issue and that this report is fiind in Romanian Country KIt 2013
All other report runs(reports that uses XMl), i dont have any problem, except this report that uses the VBA
If anyone can tell me a solution, I will be grateful
I could be wrong but I believe VB has not been supported in civil3d since 2010
Your Name
Ok.
But why i have that Microsoft visual basic probem?
Why in Civil 3d 2012 everything was ok and in civil 3d 2013 i have this microsoft visual basic problem?
Can anyone explain?
Thank You!!!
you may have installed this for 2012: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12715668&linkID=9240618
DarrenP
In Autocad Civil 2013 i've installed VBA Enabler 2013
Can anyone tell me if there is a compatibility problem between Microsoft visual Basic v. 6.3 and Autocad Civil 3d 2013?
And if there is what could be the solution to my problem?
How about this Micorsoft knowledge base article? http://support.microsoft.com/kb/223152
