I cannot work in couple of drawings as I am getting INTERNAL ERROR: !dbmaini-core2d.cpp@1796: eHandleInUse. Any idea what does it mean as google search didn't help. I tried recover, audit, delete temp. files, purge, reboot, etc but didn't help. as mentioned, it happens only on one project and few drawings (not all) which are part of that project. Appreciate any help!
I don't find anything on that, either, other than this thread and one other lonely plea.
Want to be expeditious? Get the backup, rename it as a .dwg, open that. Does it work? Go forward from there.
I don't necessarily think your error is unfixable, but, many times, it takes longer trying to fix, often still failing, than it does to step back and then continue.
This illustrates the need for reliable backup.
Renaming a backup didn't help....based on a content of error, is it possible to figure out if this is Cad or PC related problem?
Thanks.
Few guys in the office can open it and few can't. I was hoping to hear from someone, based on error wording, is it related to hardware or not. dbmaini, what does it mean? core2d, is it related to CPU or something else?
Had the same problem here on 2017, and I managed to fix it by changing settings in Options / Open and Save.
Things that I changed:
- Save format 2010 (was 2007);
- Maintain visual fidelity for..... = box empty;
- Incremental save to 100 %;
- Thumbnail preview settings - slider to 'performance'.
It is possible that you do not have to change all of these steps.
