Hi! I have a design and technology assignment that I am doing at
school. The task is to design a natural environment where there is a
need and that benefits the community. I have chosen to design a 9-hole
golf course. What I am unsure of is what software to download so I can
complete the project as efficiently and as easily as possible. Could
you please suggest some software that might be able to help me? Kind
Regards, Matt.
Thank you.
Infraworks is probably your best option for this type of work. It's intended to be used for conceptual design, and can pull data from a variety of online sources to build surface and other models.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
If you like to design by pushing and pulling contours around I like using civil 3d grading infill.
my work flow starts with a closed alignment that approximates the limit of grading, surface profile existing, then extract a feature line and infill this feature line. the initial contours act as a guide
First I would add additional closed feature lines to define tee boxes and greens and any pads. next I draft in poly line contours at elevation or extract some from the initial infill (weed), spline them and add to the grading as break lines. Careful with the number of vertices at this point.
My experience less is more and adjust the supplement value to attain smoothness. Now I can push and pull the contours and get dynamic results (judicius gripping helps maintain slopes. the limit of grading can be adjusted and the infill will update too
Joe Bouza
Did you (or can you) include control points to demonstrate that the accuracy is equal to or better than 0.5m?
Can you develop the basemap, that is - draw in the missing features, like fairways, and provide the imagery as supplemental data?
Depending on what software they are using to design the new holes I would probably export the surface you developed from the imagery in a LandXML format. If they are using a non-Civil 3D AutoCAD application you might give them the surface as represented by AutoCAD objects - 3dpolylines for breaklines, 3dfaces for the TIN, polylines for contours.
I generally make sure my data and drawings are correct and complete, then export in any number of formats for use by others. If they are not using Civil 3D make sure you export the C3D dwg to AutoCAD.
You did not mention this but you are going to need several good quality CONTROL POINTS throughout the project for you to get good contours.
Bill
thanks for your help! There is the option of adding ground control points when processing the map. however there is another feature in dronedeploy software that allows you to calibrate the map by adding a known elevation to a certain point. So i believe the map is quite accurate within itself. i cannot draw the basemap. i actually dont havve autocad. I only have the maps and data that the designers can use.
@drenaudwrote:Did you (or can you) include control points to demonstrate that the accuracy is equal to or better than 0.5m?
Control Points - There should be a number of control points on the ground (they physically exist, like an iron bar driven into the ground) whose XYZ positions are known by an actual GPS survey or other acceptable method. You then process your photos holding the known locations of the control points and forcing the rest of the imagery solution to adjust itself to the known control points. Does that make sense? When you say "i believe the map is quite accurate within itself" this is great, but how do you know for sure without using control points? How do you relate the map to the real world? Someone is going to have to build this thing and they will need control to do it.
I assumed that you were using AutoCAD since you are posting to the Civil 3D forum. Civil 3D is a set of civil engineering tools based on AutoCAD. When you run C3D you run AutoCAD. It's a good practice to indicate which software and version you are using when posting to the Autodesk forums, the replies you receive will be more relevant if you do. You might be better off contacting dronedeploy for help and support.
