Hi, i have a problem with ratining wall subasmbly... i create corridor with it, but when i try to create surface form this corridor, corridor surface jump from rw hitch point without covering the wall face and top. in attachments you can see sutiation... how can i fix this...
thanks...
Solved by Joe-Bouza. Go to Solution.
Is you surfeca built with top links>> add as breaklines>> (overhang correction)= top links?
Joe Bouza
