Can I do this?
It is for entities of Autocad, but alignments are entitites of Autocad?
Public Shared Sub ZoomToEntity( _ ByVal entityId As ObjectId) Dim db As Database = Application. _ DocumentManager.MdiActiveDocument.Database ' start transaction Using trans As Transaction = db. _ TransactionManager.StartTransaction() ' get the entity' extends Dim ent As Entity = trans.GetObject( _ entityId, OpenMode.ForRead) Dim extends As Extents3d = ent.GeometricExtents ' configure the new current view ZoomToWindow(New Point2d( _ extends.MinPoint.X, _ extends.MinPoint.Y), _ New Point2d( _ extends.MaxPoint.X, _ extends.MaxPoint.Y)) trans.Commit() End Using End Sub ' the command for database extension <CommandMethod("zextends")> _ Public Shared Sub ZoomExtends() Dim db As Database = Application. _ DocumentManager.MdiActiveDocument.Database 'get the database extension's points ZoomToWindow(New Point2d( _ db.Extmin.X, db.Extmin.Y), _ New Point2d( _ db.Extmax.X, db.Extmax.Y)) End Sub
http://adndevblog.typepad.com/autocad/2012/07/implementing-zoom-commands-with-net.html
Other way could be this:
public static void ZoomObjectoSeleccionado(Autodesk.AutoCAD.DatabaseServices.ObjectId[] matriz) { Autodesk.AutoCAD.Internal.Utils.SelectObjects(matriz); Autodesk.AutoCAD.Internal.Utils.ZoomObjects(false); System.Windows.Forms.Application.UseWaitCursor = false; }
But with zoom I don´t want to select alignment.
Yes, the code snippet in the AutoCAD DevBlog should work fine for Civil 3D entity as well.
Partha
