I want to do this:
http://adndevblog.typepad.com/infrastructure/2012/10/getting-civil-3d-land-featureline-vertices.html
to get vertex of feature lines.
However, I have to select a Reference:Autodesk.AECC.Interop.Land
Can I use that Reference for Civil 3D 2014? is there limitations for Interop in Civil 3D to feature lines?
I use(agreate) all these References?
Thank you.
You need to reference the COM Interops from Civil 3D 2014 installation folder.
Check this post -
http://adndevblog.typepad.com/infrastructure/2012/04/com-references-on-civil-3d-2013.html
Partha Sarkar
Thank you.
I needed "AEC.Interop.Base" and "Autodesk.AECC.Interop.Land".
One question.
Is it possible to get vertex off Survey Figures and Parcels?
I don´t see them in .NET API or COM.
