ok, the add dummy tangent and remove later works.
Still, must be a better way.
James Maeding
|>sure enough, the AddFixedCurve1 will not work without a previous object ID.
|>I'll try adding a dummy tangent and removing later
|>James Maeding
|>|>I have a list of segments, and want to make an alignment.
|>|>I looked at the align.entities methods for an hour and could not figure out which one to use for an alignment starting
|>|>with an arc.
|>|>I would like to use AddFixedCurve1, but it has a previous objectid parameter.
|>|>I cannot assume the segment after the arc is tangent.
|>|>Maybe I have to start with a tangent and delete it later?
|>|>Any help appreciated.
|>|>James Maeding
|>|>Civil Engineer and Programmer
|>|>jmaeding - at - hunsaker - dotcom
|>James Maeding
James Maeding
