Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
What´s the difference between Vertices and Vertice (API)?
2 REPLIES 2
joantopo
445 Views, 2 Replies
Hi.
I have this:
   using (Transaction trans = db.TransactionManager.StartTransaction())
                Autodesk.Civil.DatabaseServices.TinSurface tinSurface = trans.GetObject(surfaceId, OpenMode.ForRead) as Autodesk.Civil.DatabaseServices.TinSurface;
                foreach (TinSurfaceVertex vertice in tinSurface.Vertices)
                    Autodesk.AutoCAD.Geometry.Point2d punt = new Autodesk.AutoCAD.Geometry.Point2d(vertice.Location.X, vertice.Location.Y);
                    vertexColeccio.Add(punt);
 But foreach vertice in Vertices(TinSurfaceVertexCollection) ,it has also a "Vertice" property. Curiosly,they are various.
I don´t understand what is it "Vertice" .
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
2 REPLIES 2
joantopo
in reply to: joantopo
Solved.
"vertices" are vertex that they are around the vertex and conect with it.
In documentation API:
"Gets a TinSurfaceVertexCollection which contains all vertices connecting with the vertex object."
Partha.Sarkar
TinSurfaceVertex -> This class encapsulates a triangle vertex in a TinSurface.
TinSurfaceVertexCollection -> This class encapsulates a collection of TinSurfaceVertex objects.
Cheers,
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Rail Community
