Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
what it takes to upgrade vb.net project to 2012, any surprises?
11 REPLIES 11
Message 1 of 12
wang890
546 Views, 11 Replies
so for this year same as before just open the project and specify a new search folder path for all the com and .net dlls from autodesk then change the application class whatever to 9.0? anything else that maybe tricky like one of the other year if i remember right.
just asking this so to be sure and carry on with upgrading later tonight.
oh, also for 2012 is it possible to ditch all com and move to .net? is it as good as autocad .net exposure now? look forward to that.
still no multicore support i guess. render my new computer quite useless compared to core 2 even. got more than 13pt on cinebench doesn't mean much when comes to civil 3d.
thank you.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
11 REPLIES 11
Message 2 of 12
Jeff_M
in reply to: wang890
Moving to 2012 is pretty much as you describe. If you are using VS2010, I believe you can complie for .NET4.0. If using VS2008 and want to Debug in 2012, there are some things you need to do....I think Kean Walmsley outlined this shortly after the 2012 release.
No, not fully ported to .NET so COM is still needed....but, it is getting better. Especially Surfaces for 2012.
Jeff_M, also a frequent Swamper
Message 3 of 12
Jeff_M
Oh, there was one big issue....not sure if they corrected the SP1 download, but after installing SP1 for C3D2012 the COM references were no longer able to be located. I was sent a REG file to install which fixed this, so if you run into this issue, just let me know and I'll get that REG file to you. (A search back in this forum to around the time the SP was released will give you all the details.)
Message 4 of 12
wang890
hey Jeff
i got it upgraded ok but can't debug. says
no symbols are loaded for any call stack frame. the source code cannot be displayed
to investigate further
browse to find source
also still says can't debug in x64. should i set project to x64 not any cpu?
thanks
Bob
Stantec
Message 5 of 12
Alfred.NESWADBA
I'm not Jeff, but I'm here at the moment 😉
If you upgrade your projects to 2012 you should also change the Framework to 4.0, look to Jeff's post 2 of 4 in this thread.
As long as you haven't changed (or did some tricks with acad.exe.config) you have no chance to get it into the debugger to stop at breakpoints.
Is that the exact message? Or does VS tell you "you can't EDIT in 64bit mode"?
If the message is "you can't edit" than it's a fact of VS2010 and 64bit ... there is no chance to edit-while-debug. Sorry.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 12
Jeff_M
No, leave it set at AnyCPU. You should be able to step through using Debug, but you will not be able use Edit and Continue....that is an issue that you'd have to take up with Microsoft, no one can use edit & continue in a 64bit app. (The app in this case is Autocad, not your dll).
Message 7 of 12
wang890
hi Alfred
thanks for replying.
this is what i get. but somehow when step out it will to through the command method sub which is a different class file.
i set 4.0 yesterday after seeing that message right away but didn't make any difference. no edit is fine i am used to it already. but somehow on microsoft if you search debug x64 class library they said oh just change the cpu or something then should work. i guess not for autodesk .net stuff.
Stantec
Message 8 of 12
Jeff_M
Read Kean's blog about this....FIBERWORLD that should get you up and running. I'd forgotten about this...
Message 9 of 12
Alfred.NESWADBA
>> this is what i get
What I can imagine then (and you look into) is:
  • could it be that you have startet AutoCAD but have not NETLOADed your DLL yet (or is the assembly not loaded yet?
  • have you set your project to RELEASE- instead of DEBUG-mode?
  • and within VS: menu "Tools" ==> "Options" ==> group "Debugging" - "General": is the option "Enable just my code" checked?
Just found: also Kean Walmsley has a blog in this: <<<here>>>
[EDIT] OK, Jeff is the faster one 😉 [/EDIT]
HTH, - alfred -
Alfred NESWADBA
Message 10 of 12
wang890
in reply to: Alfred.NESWADBA
ok. apparently some old school dude is using windows xp 32bit and said my program doesn't work. got the following messages.
so what it takes to make this work for windows xp 32bit? i was thinking about .net 4.0 not installed but then when you install c3d 2012 it will install all those.
rename .doc to docx if can't see. interesting. using word 2010 but xp 32? lol.
Stantec
Message 11 of 12
Jeff_M
Without seeing your code it will be a huge guessing game. Our application runs in both 32 & 64 bit flavors with the same DLL, so it can be done without much, if any, hoop jumping.
Message 12 of 12
wang890
in reply to: Jeff_M
i have set to all cpu.
here are the code that is accessing all the autocad and civil3d com objects.
Imports System
Imports AutoCAD = Autodesk.AutoCAD.Interop
Imports AeccLandLib = Autodesk.AECC.Interop.Land
Imports Autodesk.AECC.Interop.Roadway
Imports AecUIBase = Autodesk.AEC.Interop.UIBase
Imports Autodesk.AECC.Interop.UiRoadway
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports System.Runtime.InteropServices
Imports System.Runtime.InteropServices.Marshal
Imports Autodesk.AECC.Interop.Land
Imports System.Math
Imports Autodesk.AECC.Interop.UiLand
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AECC.Interop.Pipe
Imports Autodesk.AECC.Interop.UiPipe
Module ApplicationC3D
    Public oAcadApp As AutoCAD.AcadApplication
    Public WithEvents oAcadDoc As AutoCAD.AcadDocument+
    Public oAeccApp As AeccApplication
    Public oAeccDb As AeccLandLib.AeccDatabase
    Public oAeccDoc As AeccDocument
    Public oAeccRoadwayApp As AeccRoadwayApplication
    Public oAeccRoadwayDb As AeccRoadwayDatabase
    Public oAeccRoadwayDoc As AeccRoadwayDocument
    Public oAeccPipeApp As AeccPipeApplication
    Public oAeccPipeDb As AeccPipeDatabase
    Public oAeccPipeDoc As AeccPipeDocument
    Public sAcadProdID As String = "AutoCAD.Application"
    Public sAeccAppProdID As String = "AeccXUiLand.AeccApplication.9.0"
    Public sAeccRoadwayAppProdID As String = "AeccXUiRoadway.AeccRoadwayApplication.9.0"
    Public sAeccPipeAppProdID As String = "AeccXUiPipe.AeccPipeApplication.9.0"
    'version 2009
    Public Function GetCivilObjects() As Boolean
        'Try
        '    'get acad Objects
        '    oAcadApp = GetObject(, sAcadProdID)
        '    oAcadApp.Visible = True
        '    oAcadDoc = oAcadApp.ActiveDocument
        '    'get land objects
        '    oAeccApp = CType(oAcadApp.GetInterfaceObject(sAeccAppProdID), AeccApplication)
        '    oAeccDb = CType(oAeccApp.ActiveDocument.Database, AeccDatabase)
        '    oAeccDoc = CType(oAeccApp.ActiveDocument, AeccDocument)
        '    'get roadway objects
        '    oAeccRoadwayApp = CType(oAcadApp.GetInterfaceObject(sAeccRoadwayAppProdID), AeccRoadwayApplication)
        '    oAeccRoadwayDb = CType(oAeccRoadwayApp.ActiveDocument.Database, AeccRoadwayDatabase)
        '    oAeccRoadwayDoc = CType(oAeccRoadwayApp.ActiveDocument, AeccRoadwayDocument)
        '    'get pipe objects
        '    oAeccPipeApp = CType(oAcadApp.GetInterfaceObject(sAeccPipeAppProdID), AeccPipeApplication)
        '    oAeccPipeDb = CType(oAeccPipeApp.ActiveDocument.Database, AeccPipeDatabase)
        '    oAeccPipeDoc = CType(oAeccPipeApp.ActiveDocument, AeccPipeDocument)
        '    GetCivilObjects = True
        'Catch ex As Exception
        '    GetCivilObjects = False
        '    'MsgBox("Error: Civil 3D is Not open.", MsgBoxStyle.Critical)
        'End Try
        Try
            RunCvl()
        End Try
    End Function
    Public Function RunCvl() As Boolean
        Try
            Try
                oAcadApp = Application.AcadApplication
                Dim AcadProg As System.Type = System.Type.GetTypeFromProgID("AutoCAD.Application")
                oAcadApp = System.Activator.CreateInstance(AcadProg, True)
            End Try
            'If oAcadApp IsNot Nothing Then
            '    oAeccApp = New AeccApplicationClass
            '    oAeccApp.Init(oAcadApp)
            'End If
            MsgBox(ex.ToString)
            Return False
        End Try
        Try
            oAeccDoc = oAeccApp.ActiveDocument
            oAeccDb = oAeccApp.ActiveDocument.Database
            'get pipe objects
        Catch
            MsgBox("Civil 3D No doc!")
            Return False
        End Try
        Return True
    End Function
    Public Function ReleaseCivilObjects() As Boolean
        Try
            ''release roadway objects
            'FinalReleaseComObject(oAeccRoadwayDoc)
            'FinalReleaseComObject(oAeccRoadwayDb)
            'FinalReleaseComObject(oAeccRoadwayApp)
            ''release Aecc objects
            'FinalReleaseComObject(oAeccDoc)
            'FinalReleaseComObject(oAeccDb)
            'FinalReleaseComObject(oAeccApp)
            ''release Autocad objects
            'FinalReleaseComObject(oAcadDoc)
            'FinalReleaseComObject(oAcadApp)
            'ReleaseCivilObjects = True
            oAeccRoadwayDoc = Nothing
            oAeccRoadwayDb = Nothing
            oAeccRoadwayApp = Nothing
            oAeccDoc = Nothing
            oAeccDb = Nothing
            oAeccApp = Nothing
            oAcadDoc = Nothing
            oAcadApp = Nothing
            Exit Function
        End Try
    End Function
    Public Sub LoadToolbars()
        Dim cuiname As String = "C3D_TOOLS"
        Dim cuifile As String = Environment.GetFolderPath(Environment.SpecialFolder.ProgramFiles) & "\H5M\Civil 3D Tools\C3D Tools.cui"
        Dim mg As AcadMenuGroup
        Try
            'Attempt to access our menugroup
            mg = Application.MenuGroups.Item(cuiname)
        Catch ex As System.Exception
            'Failure simply means we need to load the CUI first
            Application.MenuGroups.Load(cuifile)
        End Try
        'Cycle through the toobars, setting them to visible
        Dim i As Integer
        For i = 0 To mg.Toolbars.Count - 1
            mg.Toolbars.Item(i).Visible = True
        Next
    End Sub
End Module
Stantec
Rail Community
