Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
vlax-invoke-method enumeration question (Custom Part Properties)
2 REPLIES 2
tyronebk
584 Views, 2 Replies
How do I invoke a vlax method in lisp that requires enumerations? Here's my code. It is a port of some VBA code (which works fine), to add custom properties to pipe network parts.
(defun c:PipesExtraProp( / vrs appstr acad aeccApp aeccDoc oSettings oPipeNetworkCatDef param )
(vl-load-com)
(setq vrs (vlax-product-key))
(cond
	((vl-string-search "R18.1" vrs) (setq appstr "8.0")) ;2011
	((vl-string-search "R18.2" vrs) (setq appstr "9.0")) ;2012
	((vl-string-search "R19.0" vrs) (setq appstr "10.0")) ;2013
	((vl-string-search "R19.1" vrs) (setq appstr "10.3")) ;2014
	(t (alert "This command does not support this version of Civil 3D."))
(if
(and appstr
	(or acad (setq acad (vlax-get-acad-object) ) )
	(or aeccApp (setq aeccApp (vla-getinterfaceobject acad (strcat "AeccXUiPipe.AeccPipeApplication." appstr) ) ) )
	(or aeccDoc (setq aeccDoc (vlax-get aeccApp 'ActiveDocument) ) )
		(progn
			(setq oSettings (vlax-get aeccDoc 'Settings) )
			(setq oPipeNetworkCatDef (vlax-get oSettings 'PipeNetworkCatDef) )
			(setq param (vlax-invoke-method oPipeNetworkCatDef 'DeclareNewParameter "TimeOfConcentration" "TimeOfConcentration" "TIME" "TimeOfConcentration" <<aeccDouble>> <<aeccDoubleGeneral>> "" :vlax-true :vlax-false) )
			(setq param (vlax-invoke-method oPipeNetworkCatDef 'DeclarePartProperty "TimeOfConcentration" <<aeccDomPipe>> 8.0) )
	(princ)
I can't figure out how to add the enumerations:
   aeccDouble (type AeccPartDataFieldType),
   aeccDoubleGeneral (type AeccPipeNetworkUsage),
   aeccDomPipe (type AeccPipeNetworkDomain).
Porting the code to .net would obviously be acceptable, but I have been unsuccessful there too. Thanks for any insights.
2 REPLIES 2
Jeff_M
in reply to: tyronebk
I use Ilspy to read the dll's for the Interops and examine the Types there. It looks like all of these you are interested in are 0 based, increment by 1. Then I use the applicable integer in my lisp.
     public enum AeccPartDataFieldType
        aeccUndefinedDataType,
        aeccDouble,
        aeccInt,
        aeccBool,
        aeccString
     public enum AeccPipeNetworkDomain
        aeccUndefinedDomain,
        aeccDomPipe,
        aeccDomStructure,
        aeccDomWire
     public enum AeccPipeNetworkUsage
        aeccUndefinedUsage,
        aeccDoubleGeneral,
        aeccDoubleNonZero,
        aeccDoubleNonZeroNonNeg,
        aeccDoubleDistance,
        aeccDoubleDistanceMinor,
        aeccDoubleAngle,
        aeccDoublePercent,
        aeccDoubleArea,
        aeccDoubleVolume,
        aeccDoubleElevation,
        aeccIntGeneral,
        aeccIntNonZero,
        aeccIntNonZeroNonNeg,
        aeccStringGeneral,
        aeccStringName,
        aeccStringGuid,
        aeccStringEnumKey,
        aeccBoolGeneral,
        aeccMultivalPosition,
        aeccMultivalDirection
You could also use the (vlax-import-type-library) function, then you can refer to them by name. I used to use this but fell out of the habit quite a while ago.
tyronebk
in reply to: Jeff_M
Simple as that. I had tried integers earlier but couldn't get them to work, so there must have been something else wrong with my code at that time. Works perfect now. Thanks a lot Jeff.
Rail Community
