AutoCAD Civil 3D Customization
Member
jeffwilkerson5497
Message 1 of 3 (293 Views)
Visual Basic Express 2010 and Civil 3D 2012 VB Subassemblies
293 Views, 2 Replies
07-26-2012 01:29 PM
Hi Everyone,
I programmed some VB subassemblies a few years ago in Civil 3D 2008 using Visual Basic Express  as my compiler (Not sure the version). We recently upgraded to Civil 3D 2012 and I am trying to update my subassemblies. Also I am on a Windows 7 x64 computer which I recently got.
I loaded Visual Basic Express 2010 and before I even imported nany ew subassembly code, I tried to compile the basic C3DStockSubassemblies.vbproj to see if could update the C3DStockSubassemblies.dll. I first had to go through the conversion wizard to convert the project, and then I received about 100 errors when I actually compiled it. I loaded 2008 on my computer as well and couldn't compile it to compile either.
I am trying to figure out where I start. Is it the conversion that messed things up? The x64? I am debating whether I try and troubleshoot this myselft or hire someone. I have a lot less free time now than four years ago.
Alfred.NESWADBA
Message 2 of 3 (287 Views)
Re: Visual Basic Express 2010 and Civil 3D 2012 VB Subassemblies
07-27-2012 12:42 AM in reply to: jeffwilkerson5497
And none of them you showed here :smileywink:
The most likely reason may be that you have to update the references, but that's just guessing.
- alfred -
Alfred NESWADBA
Board Manager
Daniel.Du
Message 3 of 3 (268 Views)
07-30-2012 10:28 PM in reply to: Alfred.NESWADBA
Would you please refer to this blog to check whether it helps?
http://adndevblog.typepad.com/autocad/2012/03/solution-for-many-errors-when-debugging-my-first-plug-...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Daniel Du
Developer Technical Services
Autodesk Developer Network
