i am trying to translate a Point coordinates from Paperspce to world coordinates in model space.The code i used in Land2006 worked OK but now in Civil3d 2012 it doesn't!
Private Sub GetPlais_Click()
Dim tmpnt1 As Variant, tmpnt2 As Variant, tmpPnt1 As Variant
Dim lole(0 To 2) As Double, upri(0 To 2) As Double
Dim returnobj As AcadObject
FrmGrid3.Hide
On Error GoTo Eline
ThisDrawing.Utility.GetEntity returnobj, tmpPnt1, "ÅðÝëåîå ôï ViewPort ðïõ èá äçìéïõñãçèåß ï êÜíáâïò!"
If TypeOf returnobj Is IAcadPViewport Then
Set viewportObj = returnobj
viewportObj.UCSIconOn = True
viewportObj.UCSIconAtOrigin = True
viewportObj.Display True
Scal = 1000 / viewportObj.CustomScale '= 1000 / CDbl(cbScale.Text)
Else
MsgBox "ÄÝí åðÝëåîåò ViewPort!!!", vbOKOnly, "Ó÷åäßáóç êáíÜâïõ"
FrmGrid3.Show
Exit Sub
End If
lole(0) = viewportObj.Center(0) - viewportObj.Width / 2
lole(1) = viewportObj.Center(1) - viewportObj.Height / 2
upri(0) = viewportObj.Center(0) + viewportObj.Width / 2
upri(1) = viewportObj.Center(1) + viewportObj.Height / 2
PntUpLPap(0) = lole(0): PntDoLPap(0) = lole(0): PntUpRPap(0) = upri(0): PntDoRPap(0) = upri(0)
PntUpLPap(1) = upri(1): PntDoLPap(1) = lole(1): PntUpRPap(1) = upri(1): PntDoRPap(1) = lole(1)
tmpnt1 = ThisDrawing.Utility.TranslateCoordinates(lole, acPaperSpaceDCS, acDisplayDCS, False)
tmpnt1 = ThisDrawing.Utility.TranslateCoordinates(tmpnt1, acDisplayDCS, acWorld, False)
TxtDoLX.Text = Format(tmpnt1(0), "0.##0"): PntDoLmod(0) = tmpnt1(0)
TxtDoLY.Text = Format(tmpnt1(1), "0.##0"): PntDoLmod(1) = tmpnt1(1)
tmpnt1 = ThisDrawing.Utility.TranslateCoordinates(upri, acPaperSpaceDCS, acDisplayDCS, False)
TxtUpRX.Text = Format(tmpnt1(0), "0.##0"): PntUpRmod(0) = tmpnt1(0)
TxtUpRY.Text = Format(tmpnt1(1), "0.##0"): PntUpRmod(1) = tmpnt1(1)
tmpnt1(0) = lole(0)
tmpnt1(1) = upri(1)
tmpnt1 = ThisDrawing.Utility.TranslateCoordinates(tmpnt1, acPaperSpaceDCS, acDisplayDCS, False)
TxtUpLX.Text = Format(tmpnt1(0), "0.##0"): PntUpLmod(0) = tmpnt1(0)
TxtUpLY.Text = Format(tmpnt1(1), "0.##0"): PntUpLmod(1) = tmpnt1(1)
tmpnt1(0) = upri(0)
tmpnt1(1) = lole(1)
TxtDoRX.Text = Format(tmpnt1(0), "0.##0"): PntDoRmod(1) = tmpnt1(0)
TxtDoRY.Text = Format(tmpnt1(1), "0.##0"): PntDoRmod(1) = tmpnt1(1)
Eline:
FrmGrid3.Show
End Sub
I can't understand the problem!!!!
