Hi There,
This was created by another post. Its VBA and its about editing points with a pop up dialog box, which is waht I am after. I can't seem to get this to run.
Any help is appreciated. I tried to create it as a dvb but i could not het the command to work. Ihis version might not work in Civil3d 2014??
Allan
Option Explicit
Public Sub PointTest()
Dim obj As AcadObject
Dim pt As Variant
Dim sMsg As String
Dim cgPoint As AeccPoint
ThisDrawing.Utility.GetEntity obj, pt, "Select point:"
If TypeOf obj Is AeccPoint Then
Set cgPoint = obj
sMsg = "Elevation = " & Format(cgPoint.Elevation, "0.00")
sMsg = sMsg & vbCr & "Raw Description = " & cgPoint.RawDescription
sMsg = sMsg & vbCr & "Full Description = " & cgPoint.FullDescription
sMsg = sMsg & vbCr & "Layer = " & cgPoint.Layer
MsgBox sMsg, vbInformation, "Point #" & cgPoint.Number
cgPoint.RawDescription = "new raw"
cgPoint.Layer = "Layer1" 'change the layer of the point
End Sub
