It is 2009 edition . I found no way to get them . My conclusion is this .
There is no way to programmatically get them unless the API expose them .
Ο "Michael Robertson" έγραψε στο μήνυμα
news:6330183@discussion.autodesk.com...
> Hello LS,
> Which version of Civil3D are you programming against? I have a
> sub-assembly
> I'm working on now that will need to detect where it is within the region
> so I can get back with you on what I find.
> Thanks,
> Mike
>> I develop a subassembly using VB.NET 2005 .
>> It is a lane which has a crown moving from the left edge to the right
>> edge
>> of the lane .
>> Its position is calculated using its current station .
>> It starts at the beginning of the region and ends at the end of the
>> region .
>> It is a whole region dedicated subassembly .
>> But to do this I must -programmatically- get the starting and ending
>> stationing of the region it belongs while the subaasembly runs .
>> The CorridorState exposes CurrentBaselineId .But when I try to get the
>> object I get an error .
>> Is it possible to get those stations or should I set them manually
>> through
>> properties ?
>> I tried to get them through Corridor object and C3D got stack and
>> crashed .
>> I used Process explorer to end it . Obvioulsy does not work this way .
>> Any ideas ?
>> __________ Information from ESET Smart Security, version of virus
>> signature database 4732 (20091231) __________
>> The message was checked by ESET Smart Security.
>> http://www.eset.com
> signature database 4842 (20100206) __________
> http://www.eset.com
__________ Information from ESET Smart Security, version of virus signature database 4842 (20100206) __________
http://www.eset.com
