Hello all,
I am trying to set the corredor feature line style using VB.Net. I was used to program with VBA and now I'm beginning to learn VB.Net... So, I started to write the following code and I was able to list the feature line codes:
Dim CivilDoc As CivilDocument = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument() Dim Trans As Transaction = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction Dim ObjID As ObjectId Dim i As Integer Dim Corred As Corridor Dim FeatInf As FeatureLineCodeInfo For Each ObjID In CivilDoc.CorridorCollection Corred = Trans.GetObject(ObjID, OpenMode.ForRead) For i = 0 To Corred.FeatureLineCodeInfos.Count FeatInf = Corred.FeatureLineCodeInfos.Item(i) Next i Next ObjID
But how can I change the feat. lines styles as I can manually do with "corridor > right-click > properties > feature lines" (show in the picure bellow)? Where can I found the corridor feature line properties to be able to change the corresponding codes?
Thanks a lot,
Diego Álvares
Solved!
Dim CivilDoc As CivilDocument = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument() Dim ObjID As ObjectId Dim Corred As Corridor Dim Trans As Transaction = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction Dim BaseL As Baseline Dim FeatCol As FeatureLineCollection Dim CorrFL As CorridorFeatureLine Dim i As Integer 'Dim j As Integer For Each ObjID In CivilDoc.CorridorCollection Corred = Trans.GetObject(ObjID, OpenMode.ForRead) For i = 0 To Corred.Baselines.Count - 1 BaseL = Corred.Baselines.Item(i) For Each FeatCol In BaseL.MainBaselineFeatureLines.FeatureLineCollectionMap For Each CorrFL In FeatCol CorrFL.StyleName = "Code_linhas_sarjeta" 'For j = 0 To FeatCol.Count - 1 ' CorrFL = FeatCol.Item(i) 'Next j Next CorrFL Next FeatCol Next i Next ObjID
