AutoCAD Civil 3D Customization
Valued Mentor
ralstogj
Message 1 of 2 (341 Views)
Updating VBA code to vb.net reference issues
341 Views, 1 Replies
05-30-2012 02:55 AM
Hi
I have been going thru the ADN video on updating code from vba to vb.net and have gotten everything into vb.net but the references do not seem to work the path names are not the typicsl ones I would expect and when I change them they convert back to the original paths that do not seem to work any ideas.
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
Distinguished Mentor
andrewpuller3811
Message 2 of 2 (339 Views)
Re: Updating VBA code to vb.net reference issues
05-30-2012 05:09 AM in reply to: ralstogj
From the reference versions, it looks like you are developing on 2012.
If that is so, check out this post which covers issues with 2012 com references, including a fix.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/NET-on-C3D-2012-SP1/m-p/3239124#M6012
or check out this post on adn dev blog on the same issue with fixes.
http://adndevblog.typepad.com/infrastructure/2012/05/cannot-build-civil-3d-2012-com-with-net-code-af...
Hope this is the solution you are after.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
