I have a .dwt file which I update now ang again as I work through jobs and make changes/find better ways to do things but everytime I want to over-write the old one I struggle to delete out the information in the new drawing which will form the basis of the new .DWT - i.e. I have to work backwards and delete corridor surfaces, then corridors, then profiles one-by-one, then profile views one-by-one, then junctions, then alignments one-by-one. I often find that I get this process wrong and end up with an element in the drawing that I can't then delete and have to start all over again. There must be an easier way that I'm not aware of so all advice gratefully received please. Is there a simple "delete all civil 3d elements" command?
Solved by Alfred.NESWADBA. Go to Solution.
No, nothing like that.
And it makes sense that saving to DWT does not automatically delete all geometry objects as I might want to create a DWT that contains layouts/titleblocks/district-borders (or other borders)/connection to GIS-data/and much more. I might also create a DWT for each project, so e.g. I have some specific data like all alignments for my project area.
More interesting is that:
What elements are that? Can you select them?
It might be possible that you don't see some elements e.g. if their style settings are configured to not show anything from the object, but in that case you can:
Or can you upload a drawing with something you can't delete?
- alfred -
Alfred, Thanks for your reply. wing a simple 'delete' of everything, I've been left with various feature lines and/or alignments. However, I've tried again this morning since posting this subject, and I've had much more success. Following a delete all (except a number of standard assemblies that I use) I was left with a couple of corridors and some feature lines. The corridors could be deleted manually but the featurelines couldn't. I've repeated the process by deleting the featurelines first, and then doing a delete all and this seesm to have worked much better thanks.
On a separate not, I have a couple of different template files (I do work for a few Clients and hence have their drawing frames set up in each one) so is it possible to now go into each of the other templates and 'copy across' my standard template settings that I have now updated. Again, all advice gratefulyy received.
Many thanks
