The code supplied by Andrew in this thread http://forums.autodesk.com/t5/autocad-civil-3d-customization/code-to-extract-all-surface-boundaries/... worked great in 2014 but not in 2015.
I get the following message and then Civil crashes....:(
Does anyone have time to take a look at the source code and tweak for 2015 please?
Many thanks
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by augusto.goncalves. Go to Solution.
The post you mentioned have a code and a binary version, which was compiled for 2014 (R19.1), and therefore all the Interop references are for this specific release.
To upgrade it to 2015 you need to open the original code and change all the references to 2015 (R20.0), most important the Interop references.
And just saw that this was duplicated at http://forums.autodesk.com/t5/autocad-civil-3d-customization/update-code-extract-all-surface-boundar...
And, finally, to make a .NET version that is compatible with multiple releases, like in LISP, the code must not use Early-Binding, but Late-Binding instead (just lisp is using). But as you already have the LISP working this might not be relevant... 🙂
