Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Update Code - Extract All Surface Boundaries
4 REPLIES 4
neilyj666
384 Views, 4 Replies
The code supplied by Andrew in this thread http://forums.autodesk.com/t5/autocad-civil-3d-customization/code-to-extract-all-surface-boundaries/... worked great in 2014 but not in 2015.
I get the following message and then Civil crashes....:(
Does anyone have time to take a look at the source code and tweak for 2015 please?
Many thanks
Neil
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 REPLIES 4
The post you mentioned have a code and a binary version, which was compiled for 2014 (R19.1), and therefore all the Interop references are for this specific release.
To upgrade it to 2015 you need to open the original code and change all the references to 2015 (R20.0), most important the Interop references.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
And, finally, to make a .NET version that is compatible with multiple releases, like in LISP, the code must not use Early-Binding, but Late-Binding instead (just lisp is using). But as you already have the LISP working this might not be relevant...  🙂
Augusto Goncalves
Yes this was posted twice for some reason...my knowledge of .NET and LISP is approximately zero, hence the request for assistance which was ably answered by Jeff and Tyrone.
The LISP routine works just great...:)
Rail Community
