Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Update Code - Extract All Surface Boundaries
7 REPLIES 7
Message 1 of 8
neilyj666
704 Views, 7 Replies
The code supplied by Andrew in this thread http://forums.autodesk.com/t5/autocad-civil-3d-customization/code-to-extract-all-surface-boundaries/... worked great in 2014 but not in 2015.
I get the following message and then Civil crashes....:(
Does anyone have time to take a look at the source code and tweak for 2015 please?
Many thanks
Neil
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
7 REPLIES 7
Message 2 of 8
Jeff_M
in reply to: neilyj666
Neil, I rewrote the code in lisp so it can be used in any version released to date (at least since the ability to extract the boundaries was added).
(defun c:extractallsurfaceboundaries (/ c3d c3ddoc surfs)
  (if (setq C3D (strcat "HKEY_LOCAL_MACHINE\\" (if vlax-user-product-key (vlax-user-product-key) (vlax-product-key) ) )
      C3D (vl-registry-read C3D "Release")
      C3D (substr C3D 1 (vl-string-search "." C3D (+ (vl-string-search "." C3D) 1) ) )
      C3D (vla-getinterfaceobject *acad* (strcat "AeccXUiLand.AeccApplication." C3D) )
    (progn
      (setq c3ddoc (vlax-get c3d 'activedocument)
	    surfs (vlax-get c3ddoc 'surfaces)
      (vlax-for surf surfs
	(vlax-invoke surf 'extractborder 1)
      (vlax-release-object c3d)
  (princ)
 Just copy the code to a blank text document and save it as a .lsp file (or add it directly to your acaddoc.lsp).
Message 3 of 8
neilyj666
in reply to: Jeff_M
Thanks Jeff - but it crashed when I tried to run it......:(
Message 4 of 8
Jeff_M
Add this line as the second line in the lisp:
(vl-load-com)
Message 5 of 8
neilyj666
in reply to: Jeff_M
Still the same error message.....
Message 6 of 8
tyronebk
Jeff just forgot to acquire the ACAD object. Replace *acad* with (vlax-get-acad-object) and it should work as expected.
Edit: Actually, here's the modified code so that people don't have to parse the entire thread to get it working.
(defun c:extractallsurfaceboundaries( / c3d c3ddoc surfs *acad* )
	(if (setq *acad* (vlax-get-acad-object)
		c3d (strcat "HKEY_LOCAL_MACHINE\\" (if vlax-user-product-key (vlax-user-product-key) (vlax-product-key) ) )
		c3d (vl-registry-read c3d "Release")
		c3d (substr c3d 1 (vl-string-search "." c3d (+ (vl-string-search "." c3d) 1) ) )
		c3d (vla-getinterfaceobject *acad* (strcat "AeccXUiLand.AeccApplication." c3d) )
		(progn
			(if (not (vlax-object-released-p c3d) ) (vlax-release-object c3d) )
			(if (not (vlax-object-released-p *acad*) ) (vlax-release-object *acad*) )
	(princ)
(vl-load-com)
Message 7 of 8
Jeff_M
in reply to: tyronebk
Thanks, Tyrone. I have had that variable set in my acaddoc.lsp for so long I forget that it's not a native variable. 😞
Message 8 of 8
neilyj666
in reply to: Jeff_M
Thanks Jeff and Tyrone - works like a charm now....:)
Rail Community
