Hi denler,
Could you check your code to see if you have used trans.GetObject(objId, OpenMode.ForRead).... ?
That could be causing the crash as you are trying to add data without opening the Object in OpenMode.ForWrite.
If this is not the case, its hard to guess, unless we get to see a code snippet which is crashing Civil 3D.
Partha Sarkar
So you have found a workaround to address this issue.
If you need any further help, I would request you to share a reproduceable code snippet so that I can debug into it to figure out the cause of the crash.
Cheers,
Partha
