Yes... the Imperial and Metric Catalogs are there, but the tool palette is still empty. When I get into the catalog and, say, i-drop a basic lane onto an assembly, it says:
Unable to execute the tool. Posible causes are:
- The tool is not registered properly. Please check your installation.
- The tool is from another application and is incompatible with the current application.
(See attached screen shot)
That applies to anything I i-drop on the assembly. I've repaired and re-installed... also uninstalled, system restored to before the previous install date and re-installed. Same thing. Put it on 2 computers so far... both have same problem. All the elecrical, structural... even low sodium light bulbs show up, but nothing in the way of civil.
Thanks...
