Hello All,
When we are trying to put Structure on pipe nearer to other Structure using below method
LAYOUTSTRUCTUREONLY OR using
Network Layout Tools
Civil 3D is not allowing user to put other structure till certain distance, after some distance we can put another structure. This allowable distance might be calculated based on Structure style (Size of Structure).
Is there a way to find out this distance?
The reason for asking this question is we are developing application which will put structure automatically at certain distance, but because of above reason the function is not running consistently.
Rajesh Mehta
Solved by augusto.goncalves. Go to Solution.
I have tried below two ways but not able to get the result
(setq vla_obj (vlax-ename->vla-object (car (entsel)))) (setq perm (vlax-invoke-method vla_obj 'IsPointInsideStructureRegion (getpoint))) ; error: lisp value has no coercion to VARIANT with this type: (216899.0 380313.0 0.0) ;Tried (setq perm (vlax-invoke-method vla_obj 'IsPointInsideStructureRegion (vlax-3d-point (getpoint)))) ; error: lisp value has no coercion to VARIANT with this type: #<variant 8197 ...>
What is the correct way to get the result ?
Regards
