Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
The Sync of AutoCAD Civil 3D 2012, AutoLisp, SQL
1 REPLY 1
theonlynelly
481 Views, 1 Reply
Dear all, i have a question..
From the bridge 3D model (produced by AutoCAD Civil 3D 2012), my professor told me to make a user interface from it. In the UI, for example if i click the beam of the bridge, it will pop-up the properties of the beam.
He doesn't told me how to do that, i just know that once he said that i have to use AutoLisp & SQL. As a newbie, i ask this to get enlightenment from all of you. I hope someone can guide me to solve my problem.
Thank you in advance Smiley Embarassed
1 REPLY 1
Civil 3D Bridge modeler is a Lab Tool and it doesn't have exposed API to access properties. I am not sure if you are referring to same bridge tool here or the Civil 3D subassembly / assemblies which you can use to build a bridge section. In any case, I would suggest to use .NET (VB / C#) to build your application instead of AutoLISP. And for that, start with the AutoCAD .NET API tutorials. Here are some useful resources -
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
http://adndevblog.typepad.com/autocad/
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=8007696
http://adndevblog.typepad.com/infrastructure/
Cheers,
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Rail Community
