I would find someting like a list of math expression for "decision" situation. I understand the basic one, but is pretty more difficult when i try expression with "if" for exemple.
In a pratical exemple: If P1-P2 is between 2 values = true/false
THX
ps: Sorry for my poor english
Conditional Logic Operators There are numerous conditional logic operators that you will want to be familiar with as you define decision conditions. Examples of these include: > or < P1.Y>P2.Y (or P1.Y<P2.Y) returns True if P1.Y is greater than (or less than) P2.Y. >= or <= P1.Y>=P2.Y (or P1.Y<=P2.Y) returns True if P1.Y is greater than or equal to (or less than or equal to) P2.Y. = or <> P1.Y=P2.Y (or P1.Y<>P2.Y) returns True if P1.Y is equal to (or not equal to) P2.Y. AND P1.Y>P2.Y)AND(P2.X>P3.X) returns True if both the first condition located in a pair of parentheses and the second condition located in a pair of parentheses are true. OR (P1.Y>P2.Y)OR(P2.X>P3.X) returns True as long as at least one of the conditions located in either pair of parentheses is true. XOR (P1.Y>P2.Y)XOR(P2.X>P3.X) returns True if one of the conditions located in a pair of parentheses is true and the other condition located in a pair of parentheses is false. Any of these operators could also be used in an If statement within any expression in order to test a condition and provide one of two different values. In the following example expression for a slope value, the distance from auxiliary point AP1 to the target surface is calculated. If it is greater than 0, meaning that AP1 is located above the surface (in fill), then the slope value will be –0.25. If the value is not greater than 0, meaning that AP1 is located below the surface (in cut), then the slope value will be 0.33. IF(AP1.DistanceToSurface(TargetSurface)>0,-0.25,0.33) With a combination of the right conditional logic operators, you can make all kinds of decisions.
from "Bonus Chapter 1 Custom Subassemblies": (page 33)
http://media.johnwiley.com.au/product_ancillary/18/11186038/DOWNLOAD/603819bc01.pdf
