Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
subassembly 2012 migrate to 2015
7 REPLIES 7
Message 1 of 8
374 Views, 7 Replies
I am hoping there is a quick fix.
I have a vb.net subassembly 2012 very similar to the out of the box, conditional subassembly.
This conditional subassembly is connected, let’s say to the edge of pavement.
I now need it to work in 2015 and it doesn't. no error, nothing it just doesn’t create the corridor past the attachment point. i.e eop
any suggestions here?
So I may need to recompile!
I have IDSU 2015 installed (win8.1) and it seems that all reference files and now stored in c:\program Files\Autodesk 2015
A little different from before where they were in a civil 3D folder.
Anyway I have all the reference files AcdbMgd,acmgd and AecBaseMgd but cannot find the reference file AeccDbMgd
Any suggestion???
7 REPLIES 7
Message 2 of 8
tyronebk
You will find AeccDbMgd.dll in c:\program Files\Autodesk 2015\C3D
Message 3 of 8
Jeff_M
You may also need to reference the acCoremgd.dll
Message 4 of 8
in reply to: Jeff_M
Thanks guys
At least I can compile.
However, I guess there never is a quick fix Smiley Sad
I am not getting the correct results, any suggestions for a debug workflow.
I need to see some of the values that I am testing for, so that I can trace where the error is occurring.
Message 5 of 8
Civil3DReminders
I change the change location of the dll to the location Civil 3D expects to find it. Then when I run the code I can set debug points and see the values.
A quick internet search should show you how to set the debug in Visual Studio Express, there is one on Kean's blog.
Message 6 of 8
in reply to: Civil3DReminders
thanks for the tip
I have seen the posting on Kean's blog, great value.
but are you saying you can debug an assembly code in the same way?
Message 7 of 8
Civil3DReminders
Yes. Instead of having to type NETLOAD Civil 3d should load the dll for you.
Message 8 of 8
cool, thanks very much all.
appreciated.
Rail Community
