Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Simple question on Smooth Surface Code
4 REPLIES 4
betocamelini
366 Views, 4 Replies
Hello there!
I'm trying to create a smooth surface routine, based on the Edge Midpoints, using essentially this code:
Dim oSurface As TinSurface = CType(surfaceId.GetObject(OpenMode.ForWrite), TinSurface)
Dim output As SurfacePointOutputOptions = New SurfacePointOutputOptions
output.OutputLocations = SurfacePointOutputLocationsType.EdgeMidPoints
output.Edges = ????
How can I fill the Edges parameter with all triangle edges of my surface?
Thanks!
4 REPLIES 4
Jeff_M
in reply to: betocamelini
Normally the smoothing operations are for small areas. But, you need to pass a collection of edges that you get from the triangles and/or the FindEdgeAtXY() method of the surface. You can get the XY by using a polyline to define the area you want to smooth, then use the SampleElevations() method of the surface, this will return 3dPoints wherever the polyline crosses the TIN.
betocamelini
in reply to: Jeff_M
Hi Jeff,
I appreciate your help, but perhaps finding intersection points will result
only in the intersected edges, however I really need to apply this
operation over all edges. Do you know if there is a method to obtain all
triangle edges in the surface?
Thanks a lot!
Jeff_M
You can use the GetTriangles() method, then iterate that to get the Edge1, Edge2, & Edge3 properties, adding each one to a new TinSurfaceEdgeCollection (making sure not to add duplicates).
Note that I have not tested any of this, just going by the Object model.
betocamelini
in reply to: Jeff_M
Ok Jeff, this solves my problem. This is the code I've used:
Dim triangles As TinSurfaceTriangle()
Dim edges As New List(Of TinSurfaceEdge)
triangles = oSurface.GetTriangles(True).ToArray
Dim count As Integer = triangles.Count
Dim i As Integer = 0
Do While (i < count)
edges.Add(triangles(i).Edge1)
edges.Add(triangles(i).Edge2)
edges.Add(triangles(i).Edge3)
i = (i + 1)
Loop
output.Edges = edges
Thank you very much for your support!
Rail Community
