Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Showing a Form makes objects locked.
2 REPLIES 2
RodWing
240 Views, 2 Replies
I checked off the solution on my previous post too soon. This really shouldn't be that difficult, but this has still got me stumped.
I've posted another code sample below.
When I use the sub StartMacro1 to launch my app everything appears to work fine. Using StartMacro2 displays a form with a single button whose click event calls the ProcessAllAlignments function. Calling the function via the button's click event  causes the trans.GetObject(objID, OpenMode.ForWrite) statement to throw a Locked expection.
Any ideas why that is happening?
I would also like to perform a trans.Commit() after each alignment object is updated rather than at the end of the For loop. I get an access violation and Civil 3D crashes on me when I try to do that.
Thanks.
Rod
Public Sub StartMacro1()
ProcessAllAlignments()
End Sub
Public Sub StartMacro2()
myForm.Show()
End Sub
Public Function ProcessAllAlignments() As Boolean
Dim objCol As Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection
Dim objID As Autodesk.AutoCAD.DatabaseServices.ObjectId
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
ProcessAllAlignments = False
Try
objCol = CivilApplication.ActiveDocument.GetAlignmentIds()
Using trans As Transaction = db.TransactionManager.StartTransaction
For Each objID In objCol
Dim algNet As Alignment = trans.GetObject(objID, OpenMode.ForWrite)
If algNet.SuperelevationCriticalStations.Count > 0 Then
If Not UpdateSuper(algNet) Then
Exit Function
End If
End If
Next
trans.Commit()
trans.Dispose()
End Using
ProcessAllAlignments = True
Catch ex As Exception
MsgBox(ex.Message, vbExclamation)
End Try
End Function
2 REPLIES 2
Jeff_M
in reply to: RodWing
If you are using a modeless form then you will need to lock the document, this will prevent the eLockViolation. I don't use VB enough to be able to post sample code for you.
If you wish to commit after each alignment change, you will need to start a new transaction for each one.
MarkPendergraft
    End Sub
        myForm.Show()
    End Sub
        Try
            Using docLock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument
                                Exit Function
                            End If
                        End If
                    Next
                    trans.Commit()
                    trans.Dispose()
                End Using
            End Using
        End Try
    End Function
Rail Community
