Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
show mark in point zoom
2 REPLIES 2
joantopo
536 Views, 2 Replies
Hello.
In my aplication, I have included a button with the same function that "zoomSta" from dotsoft.
It is at the end of the list (zoomsta):
http://www.dotsoft.com/freestuff.htm
However,I would like to show a temporal cross mark in point of zoom like command "zoomsta" does.
How can I show that mark and that mark disappears  when I do zoom or regen?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
2 REPLIES 2
Ajilal.Vijayan
in reply to: joantopo
Use GRDRAW function in lisp to create a Vector.
(defun c:TPNT ()
;Pick the point for Marker (setq pnt (getpoint "\nPick the Point:"))
(setq size 2);change point size in here (setq col 1);change point color in here (setq P1 (polar pnt 0.785398163 size)) (setq P2 (polar pnt -0.785398163 size)) (setq P3 (polar pnt 2.35619449 size)) (setq P4 (polar pnt -2.35619449 size)) (grdraw P1 P4 col) (grdraw P2 P3 col) );defun
Jeff_M
See THIS post to see one way to show temporary graphics with c#.
Rail Community
