I am trying to work out a way to set up my Structure Table so that I can show either the Inner Pipe Width OR Headwall Base Width to avoid having Question Marks showing in my Table? Is there a Function in the expressions that equates to a Non-Existent or Null Parameter. Ie.
IF({Inner Structure Width}=???,{Headwall Base Width})
Also, Is there a way to hide Structures from a Table, in particulat, Null Structures?
Thanks.
Ross.
Hi Ross,
I don't see Table Cell Components' Text Property taking an expression to define the if clause.
Having said that, I would suggest you to post this question in Civil 3D user Forum if someone has any suggestion / pointer for the same.
