I would like to get a settingout data for curves using vba the table sample shown in attached file.
Any advice will be appreciate.
Thank you.
Check out the reports that ship with Civil 3D. The VBA code for the reports still comes with Civil 3D 2013:
C:\ProgramData\Autodesk\C3D 2013\enu\Data\Reports\vba
Thank you sir for your advice.
I would like to ask you a question and also need your advice, what is your opinion for VBA vs C#(API) is this the time to go ahead for learning C# Program and using help from Autodesk website and leave VBA or Modify my experience in VBA.
For your Advice
Thank you.
Autodesk is recommending .NET to program for in the future. I'd have to agree with them, although if you don't plan on doing much I might stick with VBA. It appears the Microsoft has publically indicated that VBA will be supported once again and Autodesk might be inclined to bring VBA back as a supported feature of AutoCAD.
If you are going from VBA you might want to do vb.NET instead of c#.NET. There's a less of a learning curve there and there is publically available converters from c#.NET to vb.NET that do a fairly good job in most cases.
Thank you for your effort and i'm very appreciate for that.
But what i'm looking for is how to compine the curve data with spiral data as you can say in the same lable or table in civil 3d is there any way to do that with VBA.
For your Advice.
Thank you.
