Is there a way to select the scale of your cross sections from a sample line? Or is this drawing depentdent. Also how does one change the sheet size in the section view?
thanks
Erin H
Solved by Partha.Sarkar. Go to Solution.
Could you clarify on ' which scale' you are talking about here ?
Do you see this scale value in Section / Section view ? A screenshot will help here to understand the context.
Partha
Hi Erin,
Thanks for the clarification. But, I don't see any such settings or control is available and I think its as designed and calculated based on the drawing scale where as the vertical scale could be controlled as you understand, many a times change in elevation would be a fraction of horizontal distance and hence that's necessary to reduce the vertical scale.
Hope this explains.
Partha
