Hi.
I want to set all feature lines styles (about codes) from Corridor:
In Corridor Members there is "FeatureLineCodeInfo" but it hasnĀ“t any member to get/set feature line styles.
It only has the properties:
Name Description
CodeName | Gets the code name. | |
CorridorId | Gets the ID of the parent Corridor. | |
IsConnect | Obsolete. Gets or Sets whether the feature line connects to multiple points which share the same code in the same applied assembly. | |
IsConnected | Gets or Sets whether the feature line connects to multiple points which share the same code in the same applied assembly. | |
IsDraw | Obsolete. Returns true if the feature line is drawn. | |
PayItems | Gets or Sets the pay item list. |
Is there any way to do this?
Thanks.
Those should be being pulled from the code set style, why not modify the code set, turn off all baselines/regions, and then turn the corridor regions back on?
Well, it could be a way but I donĀ“t want to change the code set style. I want to change the feature line style within the corridor.
