Hi There,
Below is code to scale X,Y and NOT Z of a cogo point, I am wondering how I can incorporate all polylines and lines as well.
Any help is appreciated.
thanks
Allan
(vl-load-com) (defun c:go() (getdoc) ;select points to scale (prompt "\nSelect points to scale: ") (setq ss (ssget)) (setq len (sslength ss) ctr 0) ;get basepoint (setq p1 (getpoint "\nPick BasePoint: ")) (setq sc (getreal "\nEnter Scale Factor: ")) (while (< ctr len) (setq curpt (ssname ss ctr)) (setq obtyp (cdr (assoc 0 (entget curpt)))) (if (= obtyp "AECC_COGO_POINT") (progn (setq vpt (vlax-ename->vla-object curpt)) (setq curz (vlax-get-property vpt 'Elevation)) (vl-cmdf "Scale" curpt "" p1 sc) (vlax-put-property vpt 'Elevation curz) );end progn );end if (setq ctr (1+ ctr)) );end while (vl-cmdf "REGEN") (princ) ) ;end GO (defun getdoc () (setq prod (vlax-product-key)) (setq aecappno (strcat "AeccXUiLand.AeccApplication" (cond ((vl-string-search "\\R17.0\\" prod) ".4.0" ) ;;2007 ((vl-string-search "\\R17.1\\" prod) ".5.0" ) ;;2008 ((vl-string-search "\\R17.2\\" prod) ".6.0" ) ;;2009 ((vl-string-search "\\R18.0\\" prod) ".7.0" ) ;;2010 ((vl-string-search "\\R18.1\\" prod) ".8.0" ) ;;2011 ((vl-string-search "\\R18.2\\" prod) ".9.0" ) ;;2012 ((vl-string-search "\\R19.0\\" prod) ".10.0" ) ;;2013 ((vl-string-search "\\R19.1\\" prod) ".10.3" ) ;;2014 ((vl-string-search "\\R20.0\\" prod) ".10.4" ) ;;2015 (t "") ) ) ) (setq acadapp (vlax-get-acad-object) c3dapp (vla-getinterfaceobject acadapp aecappno) C3Ddoc (vla-get-activedocument C3Dapp) ) )
You would want to copy and modify this block of code twice, once for polylines and once for lines:
You'll want to save the elevation value of the polyline and then assign it to the polyline once scaled. You will also want to store the elevation of the line points and then assign them after scaling.
