I have made several modifications to my default right click menu in C3D 2103 - is there any easy way to transfer these modifications to C3D 2014? (i have posted to the main Civil board but no response)
Solved by andrewpuller3811. Go to Solution.
Open the cui editor in 2014 and open your 2013 cui on the right hand side of the transfer tab. Then you can drag and drop your modified shortcut menus into your 2014 cuix.
I would caution you to back up the 2014 cuix file prior to doing this as the cui editor sometimes crashes or misbehaves.
Also check the 2014 cui shortcut menus to see if there are commands there you don't want to overwrite/remove.
