Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Retrieving Properties of Building Site in Civil 3D 2015
3 REPLIES 3
111Auto302
258 Views, 3 Replies
We are trying to retrieve the Properties of Building Site in Civil 3D 2015 through the API. Is it possible to get its Property? Thanks in advance.
3 REPLIES 3
Daniel.Du
in reply to: 111Auto302
Have you ever looked into this tool? http://adndevblog.typepad.com/infrastructure/2013/04/snoop-civil-3d-2014-database.html If you could get what you want from this tool, then it would be easy to create a plugin with Civil 3D API to retrieve what you need.
Daniel Du
Developer Technical Services
Autodesk Developer Network
111Auto302
in reply to: Daniel.Du
Thanks Daniel,
We have looked into the tool but we are not able to find anything related to builiding site, kindly suggest us some solutions to retrieve building site properties.
In fact this is a MultiViewBlockReference object that is comming from ACA APIs, which is not exposed on Civil 3D references.
I made some research and could not find an easy .NET way to read them... it may be possible via C++ (most likely using Ubiquity API), but still need some deep research, in case you're willing to use C++
Augusto Goncalves
Twitter @augustomaia
Rail Community
