Is someone able to take the code in the following post and convert to DLL please??
neilyj (No connection with Autodesk other than using the products in the real world)
Well. That's certainly beyond my abilities. However, if you have a copy of Land Desktop Companion running, you can use Make Block Chart.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Your post is moved to customization discussion board as you may find more help there. http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/Request-for-C-code-to-be-compiled/td-p/...
Thanks for this -it just crashes civil 3D unfortunately...
I'll qualify that statement - C3D goes into Not Responding mode and I stopped it after 5 minutes.
I then retried with 3 very small simple drawings and the table was created but the cells were not populated with anything
You might want to try the SincPac with it's Legend Builder: http://quuxsoft.com/SincpacC3D_Help/SP_LegendBuilder.htm I haven't used it, but it kind of kills any desires I would have to make Kean's program work better.
Christopher
