Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Request for C# code to be compiled
7 REPLIES 7
Message 1 of 8
neilyj666
774 Views, 7 Replies
Is someone able to take the code in the following post and convert to DLL please??
http://through-the-interface.typepad.com/through_the_interface/2011/10/creating-a-legend-of-autocad-...
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
7 REPLIES 7
Message 2 of 8
AllenJessup
in reply to: neilyj666
Well. That's certainly beyond my abilities. However, if you have a copy of Land Desktop Companion running, you can use Make Block Chart.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 8
AlmasSuljevic
Your post is moved to customization discussion board as you may find more help there. http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/Request-for-C-code-to-be-compiled/td-p/...
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 4 of 8
Here you go.
Message 5 of 8
neilyj666
Thanks for this -it just crashes civil 3D unfortunately...Smiley Sad
Message 6 of 8
christopher
At what stage of the program running does it crash it?
Message 7 of 8
neilyj666
I'll qualify that statement - C3D goes into Not Responding mode and I stopped it after 5 minutes.
I then retried with 3 very small simple drawings and the table was created but the cells were not populated with anything
Message 8 of 8
You might want to try the SincPac with it's Legend Builder: http://quuxsoft.com/SincpacC3D_Help/SP_LegendBuilder.htm I haven't used it, but it kind of kills any desires I would have to make Kean's program work better.
Christopher
Rail Community
