Is someone able to take the code in the following post and convert to DLL please??
Well. That's certainly beyond my abilities. However, if you have a copy of Land Desktop Companion running, you can use Make Block Chart.
Allen
Allen Jessup
CAD Manager - Designer
Your post is moved to customization discussion board as you may find more help there. http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/Request-for-C-code-to-be-compiled/td-p/...
Thanks for this -it just crashes civil 3D unfortunately...
I'll qualify that statement - C3D goes into Not Responding mode and I stopped it after 5 minutes.
I then retried with 3 very small simple drawings and the table was created but the cells were not populated with anything
You might want to try the SincPac with it's Legend Builder: http://quuxsoft.com/SincpacC3D_Help/SP_LegendBuilder.htm I haven't used it, but it kind of kills any desires I would have to make Kean's program work better.
Christopher
