I have the follwoing error in C3D R2013.
Unable to cast object of type 'Autodesk.AutoCAD.DatabaseServices.BlockTableRecord' to type 'Autodesk.AutoCAD.DatabaseServices.BlockReference'.
When casting from a number, the value must be a number less than infinity
Make sure the source type is convertible to the destination type
My code is:
Imports System Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD Imports Autodesk.AutoCAD.ApplicationServices.Application Imports Autodesk.AutoCAD.LayerManager Imports Autodesk.AutoCAD.Windows Imports Autodesk.AutoCAD.PlottingServices Imports Autodesk.AutoCAD.Colors Imports Autodesk.Civil.DatabaseServices Imports Autodesk.Civil.ApplicationServices Imports Autodesk.Civil.DatabaseServices.LabelGroup Imports Autodesk.Civil.DatabaseServices.Styles.LabelSetStylesRoot Imports Autodesk.Civil.Runtime Imports Excel = Microsoft.Office.Interop.Excel Imports Microsoft.VisualBasic.FileIO.FileSystem Imports System.IO Imports System.Convert Imports Microsoft.VisualBasic.Strings Imports System.Runtime.InteropServices Imports System.Collections.Specialized ... Using tr As Transaction = db.TransactionManager.StartTransaction() Dim btable As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable) If btable.Has("vbredakdettek") Then Dim btr As BlockTableRecord = DirectCast(tr.GetObject(btable("vbredakdettek"), OpenMode.ForRead), BlockTableRecord) For Each refId As ObjectId In btr.GetAnonymousBlockIds() myBlock = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockReference) ...
I have not tried it, but I guess that the function .GetAnonymousBlockIds returns ObjectIDs of BlockTableRecords.
So change your last shown code line to:
Dim myBlockBTR as BlockTableRecord = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockTableRecord)
...does that work?
- alfred -
that works, but my code continues with:
Using tr As Transaction = db.TransactionManager.StartTransaction() Dim btable As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable) If btable.Has("vbredakdettek") Then Dim btr As BlockTableRecord = DirectCast(tr.GetObject(btable("vbredakdettek"), OpenMode.ForRead), BlockTableRecord) For Each refId As ObjectId In btr.GetAnonymousBlockIds() Dim myBlockBTR As BlockTableRecord = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockTableRecord) 'myBlock = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockReference) Dim owner As BlockTableRecord = DirectCast(tr.GetObject(myBlock.OwnerId, OpenMode.ForRead), BlockTableRecord) If owner.IsLayout Then If myBlock.Name.ToUpper = "VBREDAKDETTEK" Then
How can I then get "myblock" ?
use the function myBlockBTR.GetBlockReferenceIDs to get the ObjectIDs pointing to the blockreferences then.
- alfred -
