Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
read anonymous blocks
3 REPLIES 3
526 Views, 3 Replies
I have the follwoing error in C3D R2013.
Unable to cast object of type 'Autodesk.AutoCAD.DatabaseServices.BlockTableRecord' to type 'Autodesk.AutoCAD.DatabaseServices.BlockReference'.
When casting from a number, the value must be a number less than infinity
Make sure the source type is convertible to the destination type
My code is:
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.LayerManager
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.AutoCAD.PlottingServices
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.Civil.DatabaseServices
Imports Autodesk.Civil.ApplicationServices
Imports Autodesk.Civil.DatabaseServices.LabelGroup
Imports Autodesk.Civil.DatabaseServices.Styles.LabelSetStylesRoot
Imports Autodesk.Civil.Runtime
Imports Excel = Microsoft.Office.Interop.Excel
Imports Microsoft.VisualBasic.FileIO.FileSystem
Imports System.IO
Imports System.Convert
Imports Microsoft.VisualBasic.Strings
Imports System.Runtime.InteropServices
Imports System.Collections.Specialized
Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim btable As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
            If btable.Has("vbredakdettek") Then
                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(btable("vbredakdettek"), OpenMode.ForRead), BlockTableRecord)
                For Each refId As ObjectId In btr.GetAnonymousBlockIds()
                    myBlock = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockReference)
3 REPLIES 3
Alfred.NESWADBA
I have not tried it, but I guess that the function .GetAnonymousBlockIds returns ObjectIDs of BlockTableRecords.
So change your last shown code line to:
      Dim myBlockBTR as BlockTableRecord = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockTableRecord)
...does that work?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
that works, but my code continues with:
                    Dim myBlockBTR As BlockTableRecord = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockTableRecord)
                    'myBlock = DirectCast(tr.GetObject(refId, OpenMode.ForRead), BlockReference)
                    Dim owner As BlockTableRecord = DirectCast(tr.GetObject(myBlock.OwnerId, OpenMode.ForRead), BlockTableRecord)
                    If owner.IsLayout Then
                        If myBlock.Name.ToUpper = "VBREDAKDETTEK" Then
 How can I then get "myblock" ?
Alfred.NESWADBA
use the function myBlockBTR.GetBlockReferenceIDs to get the ObjectIDs pointing to the blockreferences then.
- alfred -
Alfred NESWADBA
Rail Community
