Hi.
In Surface Editing Operations, there is "Raise/Lower Surface".
In API 2015, there is:
SurfaceOperationRaise
But this class has very little members.
Is that class a collection? Can I create a new surfaceOperationRaise or remove all of them?
Can I define a "DeltaDefinition" or it is only to read?
I want to do a loop, increasing Raise Surface with a value.
For example:
value= 0.02
loop:
0.02
0.04
0.06
0.08
and export to a file the fill volume(from surface volume property) for each definition.
Thanks.
Solved by joantopo. Go to Solution.
Is it OK to remove all SurfaceOperationRaises?
SurfaceOperationCollection OperationColl = supNormal.Operations; for (int i = 0; i <= OperationColl.Count - 1; i++) { if (OperationColl[i].GetType() == typeof(Autodesk.Civil.DatabaseServices.SurfaceOperationRaise)) { OperationColl.RemoveAt(i); i--; } }
