Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
QuantityReportTemp.xml
1 REPLY 1
verayunita8
419 Views, 1 Reply
Dear all,
i requirement for calculated pave, base and subbase .. how to get pave value is 0.30, base is 1.27 and subbase 4.34?
i want to know how those numbers are calculated by manual ..
Do you know ??? help please .. thanks before :womanhappy:
1 REPLY 1
If I understood correctly, you want to see how the reports are generated, is that correct? If so, you can see the source code on how create the reports and calculate the subassemblies at the following folders:
C:\ProgramData\Autodesk\C3D 2013\enu\Data\Reports
C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\Civil 3D API\C3DStockSubAssemblies
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Rail Community
