Dear all,
i requirement for calculated pave, base and subbase .. how to get pave value is 0.30, base is 1.27 and subbase 4.34?
i want to know how those numbers are calculated by manual ..
Do you know ??? help please .. thanks before
If I understood correctly, you want to see how the reports are generated, is that correct? If so, you can see the source code on how create the reports and calculate the subassemblies at the following folders:
C:\ProgramData\Autodesk\C3D 2013\enu\Data\Reports
C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\Civil 3D API\C3DStockSubAssemblies
