I'd like to know where the Properties Dialog is located in the registry to try to edit default location.
I have a client that has two monitors and puts multiple dialogs on the second monitor to have a clean working space.
Layers, Toolspace, Xref Manager, etc... are holding their location correctly.
However the properties window pops up in main screen and has to be dragged over to second screen at every startup.
Any assistance is greatly appreciated.
Jonathan
Solved by Jeff_M. Go to Solution.
